I have routed my rear brake pipe out of the M/C and around the bulkhead, but near the bottom, around the same level as the M/C, just wondering if
there will be any problem due to heat, from the engine or gearbox, dont want my brake fluid boiling! If there was a problem, could i solve it by
putting a better brake fluid in?
You should be OK as long as you keep it away from the exhaust.
If you are still worried you can get heat reflective sleeving for the brake pipes.
www.thinkauto.com
