Hi All,
just finishing installing the brakes (yes i corrected the disc error!
But i'm trying to find a fitting that goes between the calliper and hose. see below.
I know i can get a female to female adapter and mate the two but i kinda wanted a single one i.e. 1/8 npt to hose
Anyone know of one?
is this one if i take the hose end fitting off?
http://www.rallydesign.co.uk/product_info.php?cPath=85_248_249&products_id=13346&osCsid=53tkl8jfcjk9ssggt6qir9kiu2
fittings
are you saying you want a hose fitting with nptf i.e. tapered thread?
never come across that - the brake fitting seal uses cones not tapered threads.
usually what is done on production cars , or was in olden times e.g. land rover, ford escort and I daresay many others, is to have a short pipe from
caliper to a bracket - than connect the hose connector to a fitting on the bracket.
you may have issues with the hose twisting if you are relying on the tapered part to make the seal - the brake pipe fittings can swivel over the
flared pipe so don't have that problem; if you follow my drift.
[Edited on 25/8/09 by 02GF74]
usually what is done on production cars , or was in olden times e.g. land rover, ford escort and I daresay many others, is to have a short pipe from caliper to a bracket - than connect the hose connector to a fitting on the bracket.
you may have issues with the hose twisting if you are relying on the tapered part to make the seal - the brake pipe fittings can swivel over the flared pipe so don't have that problem; if you follow my drift.
That link looks like the fitting you need - assuming you have a swivel fitting on the other end of the flexible hose .
what I'd do is fit the tapered fitting to the caliper - I assume that is correct and the other one in your photo ot the hose.
then use 2 female brake nuts on correctly double flared pipe; like these below.
What about a banjo fitting attached to a banjo bolt into the caliper,-3 hose to the body fitting. Puts the hose at a right angle to the caliper and pointed toward the body and plenty of flex for suspension travel
are they wilwoods, don't think they use tapered threads.
For my wilwoods, I've used a 1/8nptf male to M10x1 Male adaptor and a M10x1 female fitting on the end of my hose. I threadlocked the nptf
adaptor into the caliper.
My wilwoods came with that adaptor in the box and it seems to be the way to go, although, rally design do sell a fitting that should work:
http://www.rallydesign.co.uk/product_info.php?products_id=13346
