hi all just planned a good afternoon in the garage fixing my brakelines but im missing the final ingredients!!
P clips for some reason i forgot about buying them
question is where would i be able to pick some up what size and what fixing size rivets needed..... its too early to think, did think of halfords but
no look..... anyone got a good idea
all help welcome and thanks inadvance
cheers Mark
where in the country are you-i have a box full
If after nylon P clips try Maplins if you have one near you.
Adrian
Speak to your local electrician of failing that pop in to any electrical wholesaler as they will have all plastic and plastic coated metal ones as
used on Pyro installations, fire alarms etc
A motor factors shop may have them if you are lucky.
Mike
[Edited on 13-9-2009 by miikae]
cheers will do... breakfast is served then straight too the shops cheers again all
Solid Brake lines are 3/16" from memory.
edit = 4.8mm
[Edited on 13/9/09 by big_wasa]
edit = 4.8mm
maplins.
they are pretty cheep too. i used 3.2mm rivets.
