are you supposed to use new prop to diff bolts when you fit a new prop ?
Worked out they were M10 x 1.0 x 18mm bolts. Ford are out of stock (according to my local dealer). So if my local fastener people can't supply
something I'm left with the four old bolts !!!
Logic says buy some new ones, supply says use the old ones !!!
I don't think there is any problem as long as they are in good condition, clean off that blue poo they use and reapply loctite, torque up to the
(?) specified torque, and drop the clutch
they're not these so called "stretch" bolts then ?
Clean off the old "blue" poo reapply new "blue" poo, torque them up and off we go then.
"Ma why's this poo blue ?"
I have never heard of them being stretch bolts, I never even used to clean them up on the 100 or so Mk2 escort clutches I changed all those year ago!
that blue poo is also very expensive!!!
It's vibration resistant, medium strength thread lock.
axle!! These are 7/16 UNF high tensile quality bolts. And yes, I'm using new items, because the old 'uns
were too crapulous to re-use. quote:
Depends on your attention to detail. The standard one is satisfactory but is about 1" too wide for the MK Chassis. This causes an angle when fitting up to the side panels. Though this can be obscured by piping! We prefered it to fit this way - IMHO! I understand the new rear panels are being designed as we speak (MK advice). There are a couple of guys on here who have done the same, but we weren't the first! AFAIK MK9R was!
Not on my ("English"axle!! These are 7/16 UNF high tensile quality bolts. And yes, I'm
snip
[Edited on 31/3/04 by Dick Axtell]
Ah an axle off a MK1 Escort MKII English axles are the same metric flange fitting as the Salsbury mini Atlas type.
