Sierra Steering Column - Support
Daddylonglegs - 28/9/09 at 10:10 AM
Hi all.
Anyone got any piccies of the 3-part bearing fitment for the Sierra steering column?
I have a new one (it's the plastic affair) but not sure how it fits (including the grip washer that fits on the triangular shaft).
I've made a support that is welded to the pedal box support so the bearing will sit at 90deg to the shaft, but not sure which way round things go.
JB
40inches - 28/9/09 at 10:32 AM
Be better to use one of these http://simplybearings.co.uk/shop/p22810/SBPFL205+Oval+2+Bolt+Pressed+Steel+Bearing+Housing+with+25mm+insert/product_info.html
Press the plastic centre bush into bearing, fit shaft, tighten flange onto bulkhead, job done and no bearing drag
