I'm using an escort steering rack which has been shortened in an attempt to reduce "bumpsteer". The track rod ends have been extended. They were
cut,extended with seamless tubing and then TIG welded. Does anyone know if this is an acceptable solution when it comes to SVA?
Regards, Ian.
