Hi all
I have been informed that the book upper wishbones give you a castor 2 to 3 degrees, which leaves you with no self steer. Self steer is the ability of
a motor vehicle to straighten itself up after leaving a corner for example. It has been suggested that I increase in the castor to 6 degrees to
improve safety and driving comfort.
your comments on this would be appreciated.
Jayce
This has been discussed many times. try using the search feature for things like "book errors" or "castor angle"
i noticed the other day when my sierra hubs were off, that the axis of spin if in front of the line between upper and lower ball joint pivot centers, ie the opposite of trail. this might be why it is so hard to get self centering. i intend to turn the mushroom to put the hole at the front, hence helping it to line up better, and then to also have a lot of castor.
the book states 5 1/2 degrees, but the drgs are wrong.
atb
steve
Hi!
Can somebody tell what will hapen if I build car with negative steering offset ( I mean - the distance D in the drawing will be negative).
Will there be any self-returning steering or steering wheel will tend to do the opposite?
Of course, I can correct the situation by placing wheel spacers, but is it a real problem?
distance d is a combination of kingpin angle and scrub radius. It depends on which one you make extreme. Too much kingpin will ruin the wheel angle in
a corner, scrub want to be low to keep the steering light.
which were you going to change?
The castor needs to be as much as possible 5.5 is about the max you can use on the Cortina upright trouble is Increase the castor and king pin
inclination needs to be increased also -- the only way to do is use negative camber -- quite a lot.
Scrub radius dosen't make the steering heavier to turn when standing still BUT it does when cornering and it greatly increases nasty kick
back.
this drawing is from mark alanson i think
any way it should give you 5 1/2 degrees castor
cheers dave
I thought distance D WAS the scrub radius...... I'm putting mx5 uprights on mine & have noticed in the course of measuring up that the scrub
radius is 0! And that's also mazda's claim, I've since discovered. I believe some of the (very) old Audi 100s had a negative scrub
radius which they made lots of bold claims about in their adverts (in conjunction with their "diagonal dual circuit brakes) - I think I'm
talking early 70s here...
cheers
Bob
Originally posted by britishtrident
The castor needs to be as much as possible 5.5 is about the max you can use on the Cortina upright trouble is Increase the castor and king pin inclination needs to be increased also -- the only way to do is use negative camber -- quite a lot.
Scrub radius dosen't make the steering heavier to turn when standing still BUT it does when cornering and it greatly increases nasty kick back.
cheers
Bob
Zero scrub radius = dead handling?? thousands of mx5 drivers will give you an argument over that.......
I'll agree it reduces tramlining and kickback, but that sounds like a good thing to me!!!
Bob
PS effect of positive scrub radius + kingpin inclination is that the car is actually lifted when not straight ahead - so it will try to self centre
even when stationary..... discuss ;^)
Hmm... My probles is that I'm using BMW uprights with shock glass. Normaly KPI is normal and scrub radius is positive, but as I hav to cut off part of shock glass, kpi changes, and scrub radius reduces till some negative value. So I need to find wheels with different offset.
