brake set up
bigsteve - 24/10/09 at 07:13 PM
hello i'm new to the forum
i've bought a part built locost with fireblade engine. As a track car is nearly finished but i'm going to put it through a iva at some point and have a few things i'm not sure about.
there is 2 brake lines coming out of the master cylinder, one going to the front and T'd off to run to either side and one line runs to the back and is split just like the front. is it a iva requirement to have one output of the master cylinder running to opposite corners?
on another note , is it worth getting a sva book or has alot of things changed for the iva?
thanks
steve
AdrianH - 24/10/09 at 07:17 PM
I believe your brake system will be fine, mine has one line to the back brakes and the other to the front.
It should be a split system but front on one circuit and rear on another is fine.
The IVA manual can be downloaded on line at
This linky
Hope that helps
Adrian
rusty nuts - 24/10/09 at 07:56 PM
Welcome to the forum. Not sure if many things have changed as regards SVA/IVA but have a look in the IVA / legal section for IVA info . Sorry can't do a link
bassett - 25/10/09 at 10:59 AM
if you have seperate master cylinders do you have a bias bar? if you do this must be welded the correct position so it cannot be adjusted.
Id say book the iva as the if it fails atleast your only fixing things you know need to be fixed rather than guessing from opinions off here etc as each tester has an individual interpretation of the rules.
bigsteve - 26/10/09 at 08:06 PM
i only have one master cylinder
bit of a diagram how it is
