I have linked my 4 pots as shown, but could someone tell me if I have used the right combination of holes. Thanks
Can't really tell from the piccy, but looks wrong to me. Any extra pipe would be from one side of the calliper to the other(if not done internally), and both sides should have a bleed nipple.
That seems to be the problem, knowing exactly which ones to join. It would appear to have been a common enough mod and yet finding out how it was done is proving difficult. I guess I need the escort boys of the 70's who did it most!
from one side to the other on the caliper is indeed done internally. What you need to do is link the two "top" holes (the two together) and connect this link to the new "supply". I.e. put in a T-piece and supply them both together. I think the hole near the pads that you have connected to is the other bleed screw hole. if you look at the two holes together at the "top" of the caliper, one supplies the bottom pair of pistons, the other the top (which is the idea for safety on the princess etc) these two need connecting, the flow from one lower piston or upper piston to it's opposite number is done internally.
It sounds to me as if it is perhaps going to be easier to have a t piece at the chassis end and have two braided hoses going in as it is suppose to, as I understand it. Mmm!!! More expense. Besides there is not alot of room round 13 inch rims to do great deal.
Sean I have u2u
I have this set up and a I belive it to be the same as your picture
I presume that i got it right as my brakes are about 50% better than the old m16 setup
regards
steve
Any chance you could double check that please Steve?
sean
check your u2u
steve
Sean
my top conection goes from the one nearset the hub and the same lower one as yours
were your top pipe goes in is were my feed from the mastercyl goes into
I took my setup from an old for transit haynes manual
steve
Well this is how it looks now. I have used a t piece and brake pipe to make up this, which enables the use of both intakes. ( thanks to Andy and his
brake tool )It's tight but not as close as it looks. Not ideal, but at least functional. Shame about the horrible wishbones. Need to be
cylindrical!
