I need some M10 x 1 blanking plugs to blank off some master cylinder outlets..............any ideas where on earth I can get some!???
CBS do them
Linky
[Edited on 24/11/09 by maximill666]
Could Flakmonkey make you some up?
Failing that could you cut down some stainless cap heads and use a copper washer under the head to seal them up?
You could try bleed nipples.
thanks folks, quick replies! Will use CBS if I can't find any spare bleed nipples
AHA!! Just for anybody else's use, Brakes International stock a specific bung that is M10 x 1 and fits the flare like a bleed nipple but without
the hole, part no. BMP100, £1.33 ea
[Edited on 24/11/09 by NS Dev]
I always use Think Auto for stuff like this.
You sometimes get one when you buy a new master cylinder, very useful when replacing brake pipes as a temporary bung
