having a look at rally design alloy upright kits,
any one used them? any good?
advantages presume there lighter? if so how much
thanks
http://www.rallydesign.co.uk/product_info.php?cPath=1375_1594_1595&products_id=11815
Thread about them HERE
ive just looked through the other thread and what can i say excellent value, makes it not worth looking for old parts, cleaning them, refurbing if
necessary and painting
aitch
nice innit
and with those removeable steering arms wouldnt be a problem to make new ones to change the ackermans angles !!!!!!!!!
aitch
[Edited on 8/12/09 by aitch]
Originally posted by aitch
ive just looked through the other thread and what can i say excellent value, makes it not worth looking for old parts, cleaning them, refurbing if necessary and painting
aitch![]()
aitch![]()
aitch![]()
So! possible failure of the alloy upright is worth the risk, compared to cleaning and refurbishing a set of steel ones?![]()
You did read the thread to the end?
[Edited on 9-12-09 by 40inches]
just been on the phone for about half an hour with the owner of Rally Designs to check this out..
he assures me that in four years of producing these uprights that ARE based on the raceleader design they have supplied almost 300 pairs with
absolutely no returns or advice of failure
Although based on raceleader design they are made using an LM25 casting by a major component manufacturer with strict quality control which is heat
treated to avoid grain growth in the casting, this grain growth can be seen in the failed components,
although they specify a maximum vehicle weight of 700kg, this recommendation originally comes from the raceleader product and th rally designs are of
a higher quality, that he knows of they have been used in at least 1 front engined V8 successfully.
i am after speaking with him more than confident in the product. If however your not convinced then Rally Design have bought up Fords stock of cortina
uprights and they are selling them for i believe £90 a pair.
i wouldnt like to see anyones business damaged due another companies parts failing.
we will all make our own choice on this
Aitch
If however your not convinced then Rally Design have bought up Fords stock of cortina uprights and they are selling them for i believe £90 a pair.
Actually, they are the Sierra uprights, not the Cortina ones.
Thought it was too good to be true...
Alex.
