Hi,
I am considering buying the MNR reverse box for my MK Indy as i only really use the car for street use so a reverse would be ideal.
Where can i get the prop shafts for it to fit or do i just get my original shaft modified?
Also how much does it cost??
I got mine from http://www.baileymorris.co.uk/
Excellent service, give them a ring very helpful. Pro-shaft were 3 day delivery.
The longer of the props has a rubber cush drive built in to absorb shock loading from engine to diff.
MNR can supply the props
£295 with TRT, £245 without
how much are they from bailey morris??
If i buy all the aprts myself how hard is it to fit the reverse kit??
and does anybody no the weight of their reverse box??
£400 for both
I bought two both with a TRT part, cost about £250 from bailey morris. Not sure why you'd get them from elsewhere at that price.
