Dual bore master cylinder to suit sierra calipers.
Chris_R - 26/4/04 at 05:52 PM
Does anyone know the amount of preasure the standard Sierra master cylinder and servo produce? I'm trying to find a dual bore master cylinder that wil suit the Sierra calipers, but without the servo. I've heard tell that a cylinder with a 19mm bore will do the job. If anyone know's of such a master clylinder and supplier, that information would be invaluable.
Chris.
britishtrident - 26/4/04 at 06:27 PM
Early 80s base model VW Golf or Polo without servo
Euro parts sell new cylinders for pennies (well almost) but they come without a resevior so a trip to the scrappies is required -- some Ford resevoirs also fit.
Chris_R - 26/4/04 at 06:47 PM
Good stuff, there's a branch near where I work. do you happen to know if they have a push rod or if i'd need to make one?
britishtrident - 27/4/04 at 07:08 AM
You need to make one, the details of the cylinders end will become apparent when you get hold of one -- I just ground a round head on long 5/16" UNF HT bolt. Only thing to watch is that the piston in the cylinder comes back far enough to clear the recuperating port.
Chris_R - 27/4/04 at 04:45 PM
Thanks muchly. Will have a look in on the weekend.
