In the next month or so,ilk be biting the bullet and buying the suspension!
what length would i need?
the ones im looking at are the gaz shocks,are these any good?
cheers
Aaron
depends what your building, MK, Dax Locost, Haynes etc
Got mine from here
Dave Ainsworth, sorted me out over the phone. Real nice chap.
Its a locost based on the ron champion book!
I think it says in the book.
From memory I recall its something like 12" fronts and 11" rear for a book car.
Procomp should be able to sort you out with correctly sized, sprung and valved protech shocks.
http://www.procomp.co.uk/shockdyno.html
If you get on to the guy at GAZ he will tell you that the book is not correct, and tell you the correct lengths. HTH Ray
just replaced my GAZ with protechs. the protech with a spring fitted is still quite a bit lighter than the GAZ with no spring fitted.
plus there valved correctly as well
