HI all, I've posted on this a while ago - but I've still had no luck in obtaining a set.
They are the covers for the rear wheel plate where the handbrake actuating lever exits.
Escort Axle - I wonder if anyone has had any further luck in tracking them down?
Any help greatly appreciated.
Rich
i think they're hard ro get hold of now, i managed to use a flameproof shroud from an armoured cable gland same as these...
Ray
I have been looking for them for two years without any joy.
May have a go at making some out of moulding rubber at some point in the future.
I found a pair new old stock and one split with in a week of fitting
I need some too. I was thinking of using a universal bellow like the ones you get for motorcycle forks and cutting it down into slices. Then closing
off one end, haven't decided how yet
Not sure how it will look/work?
Yeah you will have a hard time finding any n.o.s of these, even if you do they will fall to pieces in no time.
Could you adapt ones from other car makes? You can still get new ones for Minis, see http://www.minispares.com/Product.aspx?pid=36299.
Hi all it would seem that Darren from Escort Tec is able to get hold of these. £10 a set. He can be contacted on 07733 280190.
Rich
