Handbrake adjuster for english axle.
Ive got intermittent spongyness in my brakes, which rightly or wrongly, im putting down the handbrake adjust ment mech on the rear drums. If only
because its clearly below par, and ive checked a fair bit of the rest of it and rebled etc.
If this something i can pick up from a decent parts place (parkers loughborough) or it it going to be a right pain to try and buy?
When i replaced the wheel cylinders i was able to buy them but it took three attempts to get the right fitting and even then i had to got for a
slightly different (smaller) bore. Although i dont think that was a bad thing.
Think in question.
- Looks ok, but serrations in adjuster are somewhat fubar'ed.
Daniel
8 inch?,i think i have some of them kicking around in the garage,ill have a look tomorrow when it,s a bit lighter
They usually don't give any trouble, even when worn. Escort rear brake problems usual problems are down to the handbrake cable being too tight
and also the stupid rubber flap thingy on the rod linkage on the left-hand-side.
Best tip is throw away the escort cable and rod and rubber flap and fit a Morris Ital (or late Marina) cable fits straight on and is very easy to
shorten. This was a fairly common mod on the Mk1 & Mk2 Escort.
Even if the adjuster is slipping it will cause extra travel but not what I would call spongeyness.
Spongeyness on 1970s Escort and Cortina brakes is ususally down to the M16 front calipers, either a pad sticking in the caliper or a sticking piston
in the caliper.
If you have standard rubber flex hoses next time it occurs you can track the problem down by clamping one hose at a time.
As you can see it has the rod and cable, so maybe that mod is worth doing, can i presume to getting a new one if i go down to a decent part place?
I think the front right is sticking a little now too, not noticable before, but ive just been for a drive and its pulling to the right a little and
feeling a little warmer.
It is mainly extra throw im feeling i guess, but also a little spongier. Drive with the handbrake most of the way on, and the bit points 2inchs higher
(only half an inch of travel) and crisp as a crisp thing.
Daniel
quote:With this, are the fittings (at wheels and handbrake lever) all the same/simlaur?
Originally posted by britishtrident
Best tip is throw away the escort cable and rod and rubber flap and fit a Morris Ital (or late Marina) cable fits straight on and is very easy to shorten. This was a fairly common mod on the Mk1 & Mk2 Escort.
