Anyone know where I can get some 4mm id fluid resistant hose to go to my Fiat m/c?
The barbs going into the m/c are too narrow to seal with the standard 6mm stuff, and I can't find 4mm anywhere.
I'm currently using some 4mm rubber breather pipe but it is seeping fluid through the walls.
Stu
What about using Fiat hoses. See the post from wicket in this thread for part numbers.
http://www.locostbuilders.co.uk/viewthread.php?tid=69243
Is that 4mm though?
Stu
Assumed it must be as it's for the smallest Fiat made, but I don't know for sure.
Which Fiat is the master cylinder from?
Mine's from a 1970's Fiat 124.
I think I've found some suitable hose on ebay so will give that a go.
Stu
