I have 13" *2.25 shock absorbers.
The AVO site says to use 8 or 9 inch springs.
Does anyone know of any good reasons why you would use the 8 inch over the 9 inch, or vice versa????
Hugh
The longest you can get in the damper is usually best as it alows more ride height adjustment. There's no dynamic reason, assuming the spring
rates are the same.
Edited to add that above statements assumes pring will fit without being compressed.
[Edited on 31/3/10 by brianthemagical]
It's purely down to intended ride height. The 8 inch spring will allow you to run the car lower should you find that the 9 inch spring still makes the car sit too high, even at the lowest height position.
That's assuming the spring seats will not hold the spring at full droop, which is bad or the longer spring is longer then tha maximum distance between spring seats.
Thanks for the info. I think I'll wait until is assembled, block to the right ride height and get the spring that will fit best at that then
Thanks again
Hugh
