copper or knufler?
franky - 3/4/10 at 09:48 AM
As above, whats the difference between the two? Sorry if it seems like a simple question
matt_claydon - 3/4/10 at 09:52 AM
Do you mean Kunifer? It's a copper/nickel alloy, stronger than pure copper I believe. Google 'kunifer' and you'll get lots of discussion.
eddie99 - 3/4/10 at 09:53 AM
Kunifer is harder to get straight and bend but personal preference is kunifer!
drury318 - 3/4/10 at 09:55 AM
Kunifer is better I think, I have seen copper used before because it is softer & easier to bend etc. I have also seen it deform to the point of closing the end off when overtightened! Dennis
minitici - 3/4/10 at 10:04 AM
Copper is prone to work hardening and cracking with vibration.
Kunifer is recommended for brake lines.
snakebelly - 3/4/10 at 10:11 AM
kunifer is also far more corrosion resistant, basically its a copper knickel alloy, we used to use tons of the stuff (or a variant of) in sea water heat exchangers in the middle east so if its good enough for sea water it should stand up to a battering underneath your car.
franky - 3/4/10 at 10:40 AM
Cheers gents, sorry for the spellnting mistake
britishtrident - 3/4/10 at 11:41 AM
kunifer is very easy to work with, some of the "Kunifer" sold might be cu-ni-fe allloy but it isn't the genuine stuff.
Genuine Kunifer has" Kunfier" printed continuously along the outside of pipe.
sdh2903 - 3/4/10 at 12:46 PM
The kunifer i've used was actually easier to manipulate than the ordinary copper stuff i used for templates, It resisted flattening at the bends much better.
Peteff - 3/4/10 at 12:49 PM
Kunifer 10 is copper, 10% nickel and iron alloyed. It's not much dearer, is easy to bend and doesn't form verdigris and go green like copper.
[Edited on 3/4/10 by Peteff]
David Jenkins - 3/4/10 at 01:31 PM
Kunifer - a name made up from the chemical symbols Cu, Ni & Fe - Copper (Cu), Nickel (Ni), Iron (Fe).
Today's trivial factoid...
sdh2903 - 3/4/10 at 03:24 PM
You going for solid line over the flexy hoses then?
franky - 3/4/10 at 05:08 PM
Yep, can't afford to run all braided and no real point!
