Has anyone got a definative dimension from the bottom (book) rail to the top most part of the engine (any) that will clear a bonnet sitting between
standard nose cone and scuttle.
I am planning on fitting a ford 2.0l dohc and havnt any bodywork to work with at the mo.
Help ??????
Ps. The motor is EFI,gearbox MT75.
[Edited on 8/5/04 by iwbunting]
Hi Ian,
Try this old thread, my response on the second page gives some dimensions, note that the overall engine height is for a carb odel not efi
http://locostbuilders.co.uk/viewthread.php?tid=8634
If you are building your own chassis I would recommend getting your nosecone and scuttle, or at least finding out the heights before finalising the
chassis height. It is relatively easy to increase the height of the chassis during its construction to accomodate the engine.
Wish I'd done this
Mick
