Had to turn the car round today so i could weld the brackets for the handbrake cable and thought ad take a few piccys (and yes i knwo the tyre is flat
One problem i do have is that the handbrake isnt working. I cant seem to pull the lever hard enought to even reach the first click. Im assuming there
is too tight bend in the cable. How tight bend is ok?
You sure your boot's big enough?
i can understand getting the girl to do some work on the car, but really she shouldnt be out of the kitchen
Originally posted by cd.thomson
i can understand getting the girl to do some work on the car, but really she shouldnt be out of the kitchen![]()
Will need to be for all the fuel its going to need
are you sure the tyre is flat?
Must be the weight of the engine.
Wow... that is indeed a large boot! Could it be classed as a Locost estate?
The boot looks mahooooosive from that angle. I have another pic which it looks big in too. Im hoping with the wheel arches, it shouldn't look too
bad.
The girl btw is my sister and she cant cook to save her life
Originally posted by James
You sure your boot's big enough?![]()
Looking good, I like straight sixes....
and you've even built a fence to stop the neighbours complaining....
clever idea for different widths. is that for really good right handes and really easy drifting in left handers
Does my bum look big in the photo, said the car
Originally posted by speedyxjs
One problem i do have is that the handbrake isnt working. I cant seem to pull the lever hard enought to even reach the first click. Im assuming there is too tight bend in the cable. How tight bend is ok?
Here's me worrying about being personal with a 'that's a rather large rear end' type quote, and I've been beaten to it on
several occasions
BTW, tyre shouldn't be a problem as it's only flat on the bottom....now, where did I put me coat...
[Edited on 15/4/10 by Daddylonglegs]
Amazing discovery ....the first locost pickup.... now why didnt i think of that....
I believe that this is the new locost with megane arse.
I see you baby, shaking that arse!!
4 of them skinny rib wheels on and it'll look real cool....
you cannot imagine how much I want to drive across america in one of those with a 50s-esque bird in the passenger seat.
Think he meant young with a 50's styley about her....
Get your drift Craig, it helps that all the pics you see are on the desert with clear blue skys...
Here you go....
Originally posted by whitestu
I know what he meant! Obviously my attempt to be funny failed![]()
