Received my shocks today, the rams yesterday. Ordered springs from faulkner, delivery Monday.
Waiting for pump.
Probably not going to fit for a while because I want to go to Newark (possibly the Monday Stoneleigh).
I'm working 10 nights straight.
Anyway enjoy the pics!
[Edited on 22/4/2010 by nitram38]
Will be good when its all fitted
May need your advice martin when we bag the p100
Are you just using it for ride height or are you going to use it for anti-roll as well?
Stop messing about & go for a full computerised active setup!
Originally posted by nitram38
The idea of the rams is to keep the spring rate constant no matter what height the car is running at. The only limiting factor is the open length of the shock.
Does that matter though? Surely you'll only be using the "high" setting for speed bumps etc, not for actual driving etc since camber etc will change with height.
how do they work? is the red thing the hydraulic cylinder? so it just pushes the spring away from the seat?
looks good. might think about adding something similar to mine at some point. its going to be very very low with the front bumper on...
ah cool
er, 2 whhel kit would do, but ideally 4 wheel depending on price. my front bumper only clears the road by about 70mm at the moment. the rear is a lot
higher, but a for wheel kit would look better
Pump arrived today, so springs and a day or two off required!
Springs from Faulkner today.
Im gonna wait a while to fit them as the springs might not work (calculated rate) and I need to get the hoses made.
I don't want the car out of action for the shows.
[Edited on 26/4/2010 by nitram38]
I got a couple of hours in changing the front shocks out. No hydraulic connections yet. I want to test drive it tomorrow to make sure the
springs/shocks work properly.
The car feels ok when I jump up and down in it but it needs a proper road test.
Rear rams and shocks fitted today.
Plumbing of pump still required.
The main thing is that my springs/shocks work as they should.
[img][/img]
very interested in a set of these (4) for my new project, looked at KW's but didn't like the cost !! any idea of what price you will be
charging ??
struggle to even get the car on/off the trailer LOL
khm check ur u2u
