When talking about the track of a car where is this measured between? Is it the face the wheel bolts up against?
John.
I think it is the distance between the centres of the tyre treads, but I stand to be corrected.
Mal
Yes, middle of tyre to middle of tyre on same axle.
Centre line of tyres but I have never seen this defined in an authoritative source such a an SAE standard.
That's interesting because it means the track will be less than the width across the mounting flanges.
quote:Which, for the sake of measure is of cause the same as from one edge to the other.
