I've been mucking about with the top wishbones on my Indy to improve steering feel and self centreing.
I have modified the bones so they have rose joints that allow for castor to be adjusted, and have set it up with 5-6 degrees of castor on each side
[was 3-4 as standard]. Toe in neg camber are both set at 1 degree.
I drove it with the new bones on Sunday and there isn't any difference as far as I can tell in self centreing or feel.
However, when reversing out of a parking space I noticed that is self centres strongly when going backwards!
If positive castor [top ball jount behind bottom ball joint] gives self centreing, how come it does it going backwards when it effectively has
negative caster?
I'm going to adjust the castor again to give 7-8 degrees, but am now doubting I'm doing the right thing!
Stu
Sounds like you've either not got enough castor or you've pushed the top joint forwards instead of backwards... Top wishbones right way
round???
Mine did that on sva, spun wishbones round and it was ok
Are you sure that your steering, rack and joints are not overly tight.
AFAIK the castor will work in forward and reverse, it will actually have a stronger effect in reverse
Sounds like you've either not got enough castor or you've pushed the top joint forwards instead of backwards... Top wishbones right way round???
I had to put about 7 degrees castor to get through sva
1 degree of toe in is loads. I wonder if this could be part of the problem?
I would have thought 20 minutes of toe is the most you would want to be running. Also have you tried toe-out instead of toe-in?
I was able to get my Westfield to self-center reasonably well with 3 deg of caster and loads of toe out. This was just for SVA though. Self centering
is pretty poor now.
Originally posted by whitestu
Not sure about toe out. I thought that tended to reduce straight line stability?
Stu
It does, after IVA it is changed back to neutral/toe in.
Could be - I'll set it parallel and see what happens. Not sure about toe out. I thought that tended to reduce straight line stability?
Stu
OK - I was thinking about stability at motorway speeds.
I'll adjust toe first then try some more caster if needed.
stu
Stu
IMO parallel is the worst of all since it leaves you with a numb reaction from the wheel before anything happens.
I favour toe-out over toe-in. High speed stability is not such an issue since these cars rarely see more than about 130mph. Toe out gives you a really crisp turn-in though, so I run toe-out all the time on my car.
Give it a go and see what you think. It will probably improve your self centering too.
Originally posted by britishtridentHow you define high speed is a bit different from rest of us
Toe-out is lethal on a road car.
As a general rule, toe-in for the road and (slight) toe-out for the track.
I would have thought about 4 degrees castor is about right - any more and you might suffer with heavier steering
I assume that the people (FROSTY and Brommers) that are stating that toe out is the only way to go, have bothered to check that the components that
are being used are the same???
Because (just for example) If toe out was preferred on Cortina uprights, but toe in preferred on Sierra, and someone was to stupidly state that it HAS
TO BE THIS WAY etc. Then I would see that as quite irresponsible and potentially dagerous in itself...
Mind you, this is just my humble opinion, you could well have checked these things, and I should prob keep my nose out.................
Tyre pressures have a big effect on self centering
Castor dosen't really give true self centering.
KPI generates true self-centering --- but Cortina uprights don't allow much KPI.
[Edited on 17/5/10 by britishtrident]
Hi
You need to get your head around the fact that Camber is affecting castor. The BIG problem with the MK is that there is no Design to the front
suspension. It has no camber gain during cornering in fact it has camber loss during cornering. So your heading in the wrong direction from the moment
you start to turn. You will need to effectively re position the chassis brackets to give ample camber gain to get any real benefit from the front
end.
And as stated by Steve Cortina and Sierra require different geometry setups to gain full advantage of whats to offer.
Cheers Matt
Originally posted by Steve Hignett
I assume that the people (FROSTY and Brommers) that are stating that toe out is the only way to go, have bothered to check that the components that are being used are the same???
Because (just for example) If toe out was preferred on Cortina uprights, but toe in preferred on Sierra, and someone was to stupidly state that it HAS TO BE THIS WAY etc. Then I would see that as quite irresponsible and potentially dagerous in itself...
I've set my front wheels parallel - I found toe-out too unpleasant (well, certainly not relaxing to drive - too twitchy). I find parallel gives
me a snappy turn-in, with good straight-line stability.
This is with Cortina uprights, for reference.
There's another factor that no-one's mentioned yet - does the car use rubber bushes, PU bushes, or rose joints? Mine uses rubber bushes, so
I would guess that my front geometry is changing very slightly as my speed increases. I'd guess that this would happen less with PU bushes, and
very little with rose joints. Is this a reasonable assumption?
On a heavy 1970s car like the Cortina with radial tyres the weight of the car distorts the sidewalls of the tyres enough to generate a "self
aligning torque", this is one of the reasons they Cortina/Granada front end dosen't have much KPI or caster the self centering is mainly
generated by the tyres.
If you look at a 1950s style suspension like the MGB or Triumph Herald which were optimised for crossply tyres you will see a lot of KPI and caster.
Originally posted by David Jenkins
I've set my front wheels parallel - I found toe-out too unpleasant (well, certainly not relaxing to drive - too twitchy). I find parallel gives me a snappy turn-in, with good straight-line stability.
There's another factor that no-one's mentioned yet - does the car use rubber bushes, PU bushes, or rose joints? Mine uses rubber bushes, so I would guess that my front geometry is changing very slightly as my speed increases. I'd guess that this would happen less with PU bushes, and very little with rose joints. Is this a reasonable assumption?
Hi
Camber castor effect. If you have poor control of the camber. You'll not be getting the best from your castor. Static camber - camber gain - the
amount of camber controlled by castor. It all has an effect on the feel, feed back and stability.
Cheers Matt
Well, I'll be having a go at getting some self centreing and feel, so hopefully the non adjustable bits of Indy geometry aren't too crap to
prevent me making some worthwhile improvements.
Stu
