Advise needed please
davrus - 23/5/10 at 05:28 PM
Hi ya, just a couple of question that i hope some one has the answer to..
1 How much clearence do you have betweena cortina rear axle and the chassis, i mean the chassis bar that runs under the axle , When the car is jacked up does the axle sit on the chassis.
2 Are adjustable steering columns IVA compliant
3 What hand brake cable do you use with the cortina axle
im sure i will ask more as i go.
Hope you guys can help me
Many thanks
Davrus
Jon Ison - 23/5/10 at 05:34 PM
1) When I put a cortina axle in mine I put 2 bits of 3/4 box on top of the chassis rail, sat the axle on top of them then made the shock brackets to suit leaving 3/4" clearance when fitted.
2) Dunno.
3) Cortina.
big_wasa - 23/5/10 at 05:52 PM
1)Atlas ? you want to get your fingers around it. I modified my chassis with info I think from "Mark Allanson".
Under the diff ? I am sure the book says you cut that out and move it forwards.
2) should be no problem at all with the column.
3) a new pair of austin allegro cables again as per book I think.
[Edited on 23/5/10 by big_wasa]
A1 - 24/5/10 at 01:03 AM
I have an adjustable steering column, got through sva no hassle...should be the same for iva
