Measure some brake discs for me please?
flak monkey - 3/6/10 at 08:51 AM
Has anyone got laying around some brake discs off an escort/fiesta they could measure for me? From 90-2000 escort and 89-95 fiesta. They were fitted to the smaller engined varieties - up to 1.6 in the escort and 1.8 in the fiesta.
The diameter should be 240mm and 10mm thick.
I need to know the depth of the bell, from the wheel mounting face to the outer face of the disc if possible?
TIA
theconrodkid - 3/6/10 at 08:52 AM
http://www.brakeparts.co.uk/all you need to know
flak monkey - 3/6/10 at 08:58 AM
Oops, should have checked there first. I thought they only listed dia and thickness.
Thanks John!
flak monkey - 3/6/10 at 09:26 AM
I do need to know the depth of the bell from the back of the disc as well, and the internal diameter of the bell if anyone can help
Mr G - 3/6/10 at 10:47 AM
I've got some from a rear disc conversion on an English axle that are off at the moment which I'm sure are 240mm 10mm. However they are at the workshop.
When I drop the wife to work later I can pop in and measure them up if you like.
flak monkey - 3/6/10 at 10:55 AM
That would be great
Thanks very much
Mr G - 3/6/10 at 11:33 AM
Any excuse to get the digital calipers out
v8kid - 3/6/10 at 01:04 PM
The ones that came with my silva were 220mm dia with a 35mm deep dish and a 130mm dia flange bore. They will not fit over Sierra hubs as fiesta hubs have a smaller dia and smaller splines although all other dimensions are the same.
Mr G - 3/6/10 at 01:33 PM
35mm
135mm tapering down slightly if my eyes don't decieve me to what looks like 133mm
Disc is 239mm by 12mm with a spigot hole of 63mm
HTH
G
[Edited on 3/6/10 by Mr G]
flak monkey - 3/6/10 at 07:51 PM
Brilliant thanks very much!
