p clips for brake lines
AndyW - 10/6/10 at 07:38 PM
Quick question,
"P" clips for brake lines, can I use the plastic ones or do they have to me the metal ones with rubber coating???
austin man - 10/6/10 at 07:44 PM
I use the plastic ones without problem for the SVA
franky - 10/6/10 at 08:32 PM
you can also use cable tie bases and cable ties.
Werner Van Loock - 10/6/10 at 08:43 PM
i used oversized plastic ones and lined them with a split old fuel line to protect the copper, if you're talking about copper lines though, otherwise plastic ones are fine.
Did same for brake lines.
wilkingj - 10/6/10 at 08:51 PM
IN used the stanless ones with the rubber shield.
However I have also used cut up cycle innertube as a filler / flexible spacer (not on this build, but on my Land Rover.
britishtrident - 12/6/10 at 12:29 PM
Use proper plastic push in brake pipe clips --- P clips don't look professional.
nz_climber - 12/6/10 at 11:07 PM
I don't understand your comment, nothing un professional about a proper p clip like pictured below, they are 100 times better than any plastic clip! They are used in the aviation industry for all pipes and wiring looms for a reason!!
eddie99 - 12/6/10 at 11:09 PM
Yep also want to know whats unprofessional about p clips. And i think you have to have p clips for brake and fuel but can have cable tie bases and cable ties for wiring only. Thats what i was told anyway.
