I have fitted a zetec to my robin hood replacing the into, however to get the inlet manifold with bike crabs to clear the brake master cylinder I'm going to fit a fiat punt unit with remote reservoir, would this cylinder provide sufficient braking to the sierra brake callers fitted?, I'm using this cylinder as space is an issue
Bike crabs? Fiat punt? Are you building a boat?
This is a car forum.
Punto,
carbs
Should be fine, should only make a difference to the brake pedal effort, this can be modified by changing the attachment point of the master cylinder
to the lever .
There are diagrams in the Rally Design catalog, Wilwood page.
Cheers snapped will try it and see what happens
the fiat m/c is a smaller dia and will improve the brakes 100% (ish)
