Im trying to link a remote reservoir up to an OE master cylinder for a project…
The reservoir is a male 7/16 UNF fitting so will require a female nut and some 5/16 copper pipe which is fine.
The master cylinder has two rubber seals and the original reservoir had 2 barbs on it which were 14mm diameter.
So what I need is a source for a bard which is 14mm on one end and ~5/16 on the other and some rubber hose, suitable for brake fluid and 5/16”
bore……
Anyone know where I can get some?
local car parts company. i got everything for my kit apart from the brake sensor which i got from rally design i think.
the rubber seals you may need someone like partco or eurocarparts
hope that helps.
dave
Where I live, local shops are a bit of a misnomer so it really needs to be online. Any other ideas?
