On the shafts to bolt into the rear hubs on a Seirra.
What were you thinking........
41mm if you are talking about the same ones I asked about a few weeks back. (the big centre nut).
What job are you doing and on what car? I thought I had to take mine off but actually could release the four bolts holding the hub to the carrier and
the whole lot came out. saved fighting that nut that has to be done up 'f' tight.
Ive recieved the sierra shafts less the hubs so i may have to make a swop if we cant do a hybrid shaft.
Drums on the outer large dia push in on the inside
