We're sprinting at Debden on Sunday and using R888s for the first time. Simple question, what should the pressures be, low to get the contact
patch as big as possible or pumped up to keep the tyre walls stiff in the corners.
It's a Velocity, weighing in about 550kg on 13x7 wheels.
16 to 20 hot. Experiment!
At 550kgs and 13" rims,so I guess your running 60 profile tyres, so I would start with 22 psi cold, around 26 psi hot, and see how it feels, you might find you have to drop a couple of psi out at either front or rear, but I dont think you will be far off at those pressures.
Is there a formula for working out tyre pressures? The reason I ask is that I recently discovered two sidewall splits in my rear tyres so I suspect that my pressures were a bit on the low side. Having just bought new tyres I wouldn't like to see them go the same way.
At Lydden last week I used 22psi in my R888's as advised by Gerald Dale Motorsports who setup the geometry and suspension on my Velocity.
I used to run 20psi but the new setup and tyre pressures where amazing. I've never had it feel so well balanced on a trackday before.
Originally posted by nitram38
Easiest way is drive on a straight road and use an infra red/laser thermometer when you pull overe to check the tyre temps across the tread.
Too hot on the outer edges, too low pressure, hot in the middle, over inflated, even temp across the tread just right
Originally posted by Mark Allanson
So the front tyre has 425lbs on 33sq ins which gives 13psi which seems really low! (But I have guessed the footprint)
Took your advice and experimented and found that at 22 the grip was amazing, shame that the engine decided to eat itself just as we found that out
