Hi all,
My name is Brett and I’m Sydney Oz.
Some of you may know me from the yahoo board.
I’m planning a scratch built mid engined roadster using WRX running gear and I’m thinking of using an IRS from a MX-5.
Problem is I want 5 stud wheels and the MX-5 is only 4.
I’ve heard on the grapevine that series 4 or 5 RX-7 brakes and discs fit. Anyone had any experience with this swap?
Also has anyone used the MX-5’s front end?
I thought it went the other way & RX7s were 5stud(!)
There's a fair degree of swappability in the mazda range, I believe some of the 323 rear calipers in particular can be used on a mx5. The
"sport 2000" rear brakes are 11" rotors and the same caliper onan extended bracket - a kit is available for mx5s - handy if you want
reasonable brake balance after upgrading the fronts (again kits available) to bigger rotors.
I'm using mx5 uprights/irs on my locost - but I've had to do a fair bit of messing around - biggest headache is rack at same level as bottom
wishbone at front, you change the upright or the whole chassis front..... I changed he upright!
Bob C
There's a fair degree of swappability in the mazda range, I believe some of the 323 rear calipers in particular can be used on a mx5. The "sport 2000" rear brakes are 11" rotors and the same caliper onan extended bracket - a kit is available for mx5s - handy if you want reasonable brake balance after upgrading the fronts (again kits available) to bigger rotors.
I'm using mx5 uprights/irs on my locost - but I've had to do a fair bit of messing around - biggest headache is rack at same level as bottom wishbone at front, you change the upright or the whole chassis front..... I changed he upright!
Brett, take a look at
http://freespace.virgin.net/bob.carter/locost_build.htm
some fotos of work in progress on front uprights near bottom. Note I also had to reduce the mad angle mazda mount the bottom balljoints at.
The hardest part is finding suitable taper reamers to finish the job off!!
Bob
PS I'd have said 4 studs were plenty on anything below a ton (even a ton & a bit...) - but you're the guy who's going to drive it!
Originally posted by bcal
I'm not sure at what HP, weight and tire width that you should go to 5 stud but it's better to be safe than sorry IMO so I'll go with 5
SO your gonna delete the awd on the subaru tranny? How are you gonna get the shift linkage worked out? I was thinking of this swap awhile back and never got the linkage solved.
