as above i got the 918 blade engine and running the 3.62 diff is this the right one
only asking because it used to have the pinto engine in it
Should be fine, i'm running a 954 blade with 3.62 diff, pulls well through gears and runs on to 116mph before it hits limiter in 6th.
also depends on tyre size. with a 919 blade i'm using a 3.54 diff on 205/60/13's. max speed in 6th would be just over 125mph.
on track i never quite get into 6th, limiter in 5th is about 120mph. when i used 185/60/13's i did use 6th.
got some slicks on the way that should bring 6th back into play
have a look here
