currently setting up castor angle for the front on a kit I'm building and would like some advice please.
I know that the nearside of car has more castor than offside to compensate for the natural curvature of the road but how much difference should there
be?
1 degree 1/2 a degree?
your help on this matter would be much appreciated but no guesses please!
I will be welding top mounts in place and it's a lot of work tp correct if wrong?
many thanks
Paul
not guessing, but i've never heard of different castor to account the road camber?
LOL
Never heard of anyone designing in variation of castor before!! Keep it equal would be my advice
I thought that the crown in the road would naturally make the car pull to the kerb.
I'm not making it up! but I can't recall where I got it from.
I was lead to believe that french cars were set up to drive to the left to allow for road camber, not sure were i got the info from, as its probably
crap
steve
There isn't always a crown in the road. If you have superelevation then a crown isn't needed for surface water drainage.
you're right, circle track cars do, but only because they always turn the same way.
i thought it was the camber that was different though?
all the yank tanks we work on pull to the kerb.
drive on the wrong side and they are fine
Hi
Sounds like rubbish from a manufacturer as an explanation as to why they cant jig the front suspension with any accurasie at all.
Cheers Matt
I would keep it equal... Self centering is usually a bugger in itself without adding complications!
VOSAman might not agree with odd split angles as a reason why it pulls to one side on their flat test area.
Keep it simple and equal.
you could always use rose joints instead of bushs, and make it all fully adjustable so you can change the camber, caster, etc
I have always set the camber to the negative end of specs on the LH side to compensate for road caber, but castor is what it should be - dead equal both sides
I don't think castor would make significant changes that would affect behaviour due to road camber. Camber might ..... but unequal camber would
surely mess up handling on flat roads (ie motorways) not to mention tyre wear. Track days would be interesting too - you would do better choosing
tracks with mainly right hand bends!
I would keep it simple ..... and symmetrical
[Edited on 1-8-10 by RazMan]
Maybe that's why my Peugeot 308 always pulls to the left then???
Asked the local dealer to check it (it's a Motability car) and they said that it needs to be checked by Slow-fit of similar as they can't
check
. Would have thought a main dealer could at least check that??
Must be equal on both sides for road use
To clear up the French car mystery the Citreon CV2 and original Renault 4 had asymetrical suspension because of the way the transverse torsion
bars were positioned.
equal it is
