carlton propshaft
tofferson4 - 25/8/10 at 07:45 PM
hy just a quick one, i have a carlton box mated to my red top and a sierra diff. The diff has got a flange for the prop but so does the gearbox , so no splines how would i make up a propshaft for this setup cheers
flibble - 25/8/10 at 07:47 PM
Quick answer is with a flange at both ends and a slider built into the centre (had to get one for my saab motor-omega box combo).
Take a peek at some Land Rover propshafts
[Edited on 25-8-10 by flibble]
blakep82 - 25/8/10 at 07:52 PM
contact someone like auto prop, dunning and fairbank, or bailey morris and they'll tell you exactly whats what
tofferson4 - 25/8/10 at 08:52 PM
thanks for the advice i have a prop from the carlton that joins on a spline in the center but in my kit car it only needs to be overall around 3 foot so each half would only end up 1.5 feet of so do you think this would be ok? cheers
Humbug - 26/8/10 at 07:40 AM
Can't see why that wouldn't be OK as long as the flanges are properly welded on each end... may need a support in the middle depending how "floppy" the middle joint is, though if it's splined it's probably pretty solid
tofferson4 - 26/8/10 at 10:16 PM
cheers for all the advice will give it try
