hi all,
what wheel and tyre sizes are people running on there cars, more so towards the higher bhp 7 type
just trying to gauge if im going to need a different set of wheels,
thanks
what engine, bhp, torque?
Whereabouts near Leeds are you?
Depends what youre looking for.
Driveability?
Accelleration?
Crusing / Top Speed?
What diff you have?
Very much down to personal taste, and the intended use of the car.
Would thoroughly recommend 13" diameter.
Front width 185 to 205
I would think with 300bhp you will light up the rears whatever the width
Al
Would have typed the same as Al for power up to 200, maybe just over.
I suppose 245's for 250bhp and slicks for 300bhp
13" rims, then the rest is trial and error I'm afraid!
200 to 300bhp out of a 1600??????
14inch yoko a021r 185's
13inch acb10's 185's on the track
But I don't have a bit less than your 200bhp.
That is some cross flow if you are making 200-300bhp.
matt
matt
"200 to 300bhp out of a 1600?????? "
thats easy, my 1600 xflow is 500
My 1600 was outputting 270BHP and that was built to produce more but I never bothered to up the limiter (belt driven Rotrex supercharger).
More than enough power for mainly road use. I was on 14" wheels with 185 section tyres. Road tyres you did have to use your right foot to
modulate the power delivery in lower gears. Semi slicks when warm were hadly ever overwhelmed but the torque delivery from a Rotrex increases almost
linear with revs.
Wheel and tyre size will have less effect than geometry, damping and weight over the wheels from what I've read.
My RX7 has relatively skinny 16" 225 tyres and 350 lbs ft from as low as 2000RPM but the 500-600 kgs (my Striker was 550kgs total) over the rear
wheels helps a lot with traction. If I was obsessed with drag racing like the yanks with similar conversions to mine I would probably be on 18s with
street drag tyres up to 295 width.
275 kumho v70 on the back of mine and still spins in first a bit
More than enough power for mainly road use. I was on 14" wheels with 185 section tyres. Road tyres you did have to use your right foot to modulate the power delivery in lower gears. Semi slicks when warm were hadly ever overwhelmed but the torque delivery from a Rotrex increases almost linear with revs.
My RX7 has relatively skinny 16" 225 tyres and 350 lbs ft from as low as 2000RPM but the 500-600 kgs (my Striker was 550kgs total) over the rear wheels helps a lot with traction. If I was obsessed with drag racing like the yanks with similar conversions to mine I would probably be on 18s with street drag tyres up to 295 width.
