Tyres and pennies
mcg - 20/9/10 at 03:39 PM
I am looking for some 195 45 15 tyres for my f27 track day car that I am building and wondered what people would recomend? Cost is a major factor at this stage. Given how much spare cash I have at the mo, the real budget ones are an option - although Nankang for example get some rubbish reviews. Part worn are also an option. I suppose I need to factor in the cost of fitting and balancing which could also lead to a false economy. I have experienced a few cases of 'buy cheap buy twice' on the project so far, but I definitly like doing things locost!
Any recomendations? Thanks as always for your thoughts.
Matt
hobbsy - 20/9/10 at 03:44 PM
Goodyear Eagle F1 or Toyo T1-R / T1-S have been as cheap as £30 per corner in either 195/45-15 or 195/50-15 in the past.
Check mytyres.co.uk
I would avoid part worns especially in this size when they are relatively cheap as its a very common size.
nick205 - 20/9/10 at 03:49 PM
What sort of timescale are you on and do you have wheels already?
If you can bide your time and watch on eBay the best value can be had buying a set of wheels and tyres - OK the tyres might be part worn and the wheels might not be your first choice, but there are some real bargains to be had.
spiderman01980 - 20/9/10 at 04:08 PM
how much you pay for a tyre, that is what you get, pay cheap get shyte, i ones went cheap(£70 each tyre on 17"s good brand £140 each, had them put on the back) when i had an imprezza wrx and every time i try to pull out on a round about in the wet it just kept sliding everywhere unlike the good brand i had on b4(i cant remember which ones) griped like it was dry! since then i`ve never gonne cheap again!
[Edited on 20-9-10 by spiderman01980]
ali f27 - 20/9/10 at 04:21 PM
Hi look for some yoko pradas very good vale way better then cheap makes
pekwah1 - 20/9/10 at 04:25 PM
hankook v12 evo is a very good tyre. There's a load of german reviews knocking about somewhere where it outperformed the toyos, goodyears, michelins etc...
also mega cheap!
spiderman01980 - 20/9/10 at 05:48 PM
linky here is a review not bad for £35 a tyre, they are best in hot weather conditions! you can type any other tyre in and it will give a review!
coozer - 20/9/10 at 06:32 PM
Yokohama Prada 2's on mine.. £125 for 4
Good tyre or the Toyo T1r's are good as well.
lotusmadandy - 20/9/10 at 06:41 PM
Another vote here for the
yoko parada 2's. I have 195/50/15's on mine
and they are a great tyre.
£150 for four corners,inc delivery.
nick205 - 20/9/10 at 08:19 PM
Parada 2s worked OK on my Indy and as above good value too.
TheKingofBling - 21/9/10 at 08:45 AM
Marangoni Zeta linea or Stunner Scudo, these are what the lads on the hillclimb/ sprinting scene are starting to use, been using the marangoni myself for the last couple of years, fantastic and cheap.
mcg - 21/9/10 at 10:09 AM
Awsome - thanks for all the inputs. The Toyo's at approx £30 would be awsome but cant see em around at the mo for that sort of money. I suppose its a case of keeping an eagle eye out for em. Thanks again.
Check mytyres.co.uk
