Has any one fitted Brembo four pot calipers as used on the likes of the Evo on to Cortina mk 5 hubs??
I have been playing around with this idea and it does not look 100miles out, some sort of bracket and mods to the calliper will be required, just
wondering if it has been tried....
Cheers Rob
Capri sport do a conversion with BMW 740 Brembo's
http://www.fordcapri.co.uk/clubs/capspo.htm
May be worth a call to them.............
what size wheel do you need to run to clear?
Depends on disk diameter and caliper thickness
Hi,
Thanks for replies.
I am looking at using a Capri vented disc, it's the v6 one and it's about 240mm. I am wanting to run 15" wheels.
With this disc I will probably need to modify the calipers a bit, which I don't mind doing. They actually weigh about the same as the steel twin
pots that came with the cortina hubs!
Rob
