coner weights
phil clegg - 20/11/10 at 11:24 PM
just had mine done in accrington £100,did fr and rear castor and camber ,track, checked bump steer,car weighed v6 engine 690kg,only one spring neede slight adjustment,saw how near and far out my build was ,i am proud to be tight but this was well worth the money..
austin man - 20/11/10 at 11:26 PM
De Ja vou
bimbleuk - 21/11/10 at 07:06 AM
You didn't mention cross weights which is an importantpart of setting up your car? Can you post the figures I'm sure you'll get plenty of feedback
a4gom - 21/11/10 at 08:06 AM
who did it?
phil clegg - 21/11/10 at 12:42 PM
weights lf189 rf178 lr161 rr 165 this was first check then added drivers ballast and did adjustment to lr,forgot to record final settings but they were close enough as not to need any more fiddling,done at phoinix motorsport 01254384071 proper straight talking chap .
