.. Just at the stage of fitting the front uprights- but im not quite sure on the orientation of them-
Is it this way(1)-
or this way(2)-
Sorry about the different angle of picture; hopefully you get the idea!
Also can any one identify the uprights? And also the brake calipers (believed to be mk2 RS2000??)
One final thing- To keep all of you who are snow bound occupied; Does anybody know a company/ person that has all the braking components for an Atlas
axle? Im running out of ideas on who to go to!
Heres what ive got in terms of brakes-
Cheers LocostBuilders
Mark.
# 2 old bean
Pretty sure they're Cortina uprights.
[Edited on 2/12/10 by Daddylonglegs]
second pick witht he steering tie rod ends facing forward and low
Smashing thanks... Ill go and get them fitted! Youll have to excuse my inability sometimes
Haha!
If anyone knows the other answers itll be greatly appreciated
Definitely cortina uprights.
Rallydesign stock Atlas axle bits
Standard m16 calipers (as fitted to cortinas, capris and some escorts) as far as I can tell
That'll be you sorted then?
yep, cortina uprights, so as per #2
BUT WAIT! the steering track rod enters the hole in the upright from underneath i'm sure? ( i don't know, i don't have them)
the hole is tapered, and the taper in the hole should fit the same way as the track rod
[Edited on 2/12/10 by blakep82]
Good spot that man! Absolutely right, it should enter from underneath.
I should have spotted that one, it's been a long day
cant you modify sierra backplates to fit the axle if so you can fit larger drums
With regards to the steering rack ends- I just put them in the holes quickly without checking; just to take the picture! And yeah, they are tapered-
so they do need to be the otherway around... Good spot anyway!
Ill have another search for Atlas Axle bits and pieces- but obviously as its such an old part; they are pretty hard to come by! I know 'Fostech
(??) engineering specialise in Atlas bits and pieces, and also do a conversion for sierra rear discs! Ill pop them an email and see what they say.
Cheers guys- Youve done me a huge favour
when i asked fostek about full floating modded atlas axles, he was, er, not very helpful. kind of like, i should know all this if i'm doing it,
and he shouldn't need to give me any advice. needless to say he didn't get my business either
