im building a single seater with bie engine and wanted to use chain drive
and wanted to know could you get away with using a solid shaft like on gokart
or will it cause to much scrubbing of tyres or winding up of the axle shaft,
the car is not going to be used on road only track toy tarmac use
so whats your opinion on this
thanks
Will understeer horribly unless you light up the tyres... then oversteer/drift. Not really any good on track.
Has anyone actually tried solid diff on track?
contact Martin Keenan at MKEngineering he has been doing this type of thing for years having recently designed built a single seater and a Midi 7 both with bike engines in the rear
start watching ebay/pistonheads etc for a quaife chain drive diff...
Or try MK as they convert a Fiesta one.
A used quaife can be yours for £350
http://www.westgarage.co.uk/services/chain/chaindrives.html
or maybe this: Diff with sprocket for Bike Engined Car on eBay (end time 19-Dec-10 20:18:50 GMT)
You may want to talk to Retropower - they've got a neet diff solution on BEC their building.
Gokart stearing geometry and weight distro is designed so that under cornering the inside wheel lifts of the ground, unless your planning to do this
for a seven, which i suggest your not, a live rear axle is not going to be clever.
Daniel
