Hi Guys,
The suspension bushes on my road car (a chevette) have gone west, and I've been quoted ridiculous dollars for the real part. (around $430, for a
car that's worth around $500 - But it's got sentimental value).
So, after doing a few searches here, I'm thinking I'll make some PU bushes (90A hardness), seeming to be most common / simplest option from
what I've seen.
But I've got a bunch of questions:
Does it need an interference fit? if so, by how much?
The crush tubes are longer than the casing on the swing arm - should I 'taper' this out?
I've got to take around 3mm diameter off the stock that I can get.
Do I have to use a lathe?
As I haven't got one, can anyone recommend reliable alternatives?
(e.g. Could I run a bolt through the middle, stick it in my drill press and use sandpaper? Maybe the accuracy would suck there).
I've been quoted from one source NZ$60 for the billet.
From another source I've been quoted $300 for final product.
Is that a likely ratio of cost?
Mechanics mostly charge around $50 /hour, so specialists, probably $80, so that'd be 3 hours work ?? Is that a bit extreme?
Thanks guys,
Greg H
I have a nephew who works with plastics and his opinion is that poly should be cast not machined.
http://www.notcutt.co.uk/polyresins.htm do a 2 part resin to 80 Durometer Shore hardness which is supposed to be easily machinable to finish it off if
you fancy trying to make your own I'm sure the same thing must be available in Nee Zooland
[Edited on 22/6/04 by Peteff]
And NZ, which would be even handier
Yes there too By the power of the Edit button.
I'm fairly sure Deflex sell a kit for the Chevette. Might be worth a look on their site (check google, but I suspect deflex.co.uk)
Complete kit for my XR2 was ~£60 delivered.
Chris
Our guys machine the stuff direct from the freezer - chill to about -20 and it machines far better. Aim for a sliding fit when cold. Minor expansion will make interference fit at room temp.
Also useful.........
Machinability
Standard procedures used to machine plastics are applicable to polyurethane elastomers.
Key Points to Remember:
Polyurethane elastomers have much lower thermal conductivity than metals, so heat generated by cutting tools stays close to the tool and raises the
polyurethane temperature rapidly. This heat must be controlled. Melting will occur at approximately 550°F (228°C).
Elastic memory—Elastic recovery occurs in polyurethane elastomers both during and after machining, and the cutting tool must provide clearance to
compensate for this. Without this compensation, expansion of the polyurethane after cutting will result in increased friction between the cut surface
and the cutting tool and, ultimately, in excess heat buildup. Elastic recovery after machining can also result in smaller internal diameters and
larger external diameters than were measured during cutting.
Modulus of elasticity—Polyurethane elastomers are resilient and can easily be distorted. Because of this, care must be taken to avoid distortion due
to holding or cutting forces.
Softening point—Gumming, poor finishes and poor dimensional control will readily occur if excess heat is generated and allowed to accumulate. Proper
tool geometry, feed rates and cutting speed, in conjunction with coolants, can usually overcome these problems. Water-soluble cutting oils and/or
light machine oils are good coolants for polyurethane elastomers.
Useful Tips:
Sawing—Use a band saw with a 4- or 6-teeth-per-inch blade with raker set. Operate at higher speed settings. Apply oil or water as cutting proceeds. Do
not force the work.
Milling—Not recommended for grades below 50D in hardness. The harder grades machine similar to aluminum. Tools must be sharp and the work must be
securely clamped. Use high operating speeds and low feed rates. Two-flute end mills and single-point fly cutters are preferred.
Grinding—In the lathe, turn the work at low speed. Set the tool post grinder for a feed rate of 0.005 inch per revolution (ipr) and use a 20-80 grit
grinding wheel at a surface speed of 6,000–8,000 fpm. Finish the stock removal per pass to a dust-type grind. Use air blasting to clean the wheel and
cool the stock. Too much stock removal at one pass results in melting or smearing of the surface. Fine abrasives can be used for final polishing.
In cases where larger amounts of stock must be removed, turn the piece down with a cutting tool to within 0.020 inches of the finish dimension before
grinding. We recommend that the grinder be equipped with a dust collector, or the operator wear an approved dust mask when grinding or sanding
Lathe turning and boring—In general, use sharp tools, a high turning speed and a slow rate of feed. Water or plastic lubricants can be used as
coolants. Cutting tools for polyurethane elastomers must have sharp, carefully honed cutting edges. Clearances must be greater than those used for
metal. High-speed steel or carbide tools are recommended.
Smooth surfaces can be achieved on heavy as well as light cuts, so roughing cuts are seldom required. In turning large-diameter polyurethane parts,
light cuts of 1/10 to 1/8 inches deep and a light feed of 0.003 to 0.007 ipr are recommended. To boost production, heavy cuts of up to 3/8 inch and
feeds of 0.15 ipr can be used if care is taken.
Drilling—Slow, spiral drills perform best because the large flute area permits free discharge of chips with a minimum of binding and heat buildup.
Retraction of the drill frequently aids in eliminating chip blockage of the flutes. Breakout tearing at the exit side can be reduced by slowing the
drill speed at the bottom of the cut or by backing with another material.
When drilling a series of small holes, inserting a pin in each completed hole prevents the force of the drill from pushing material into adjacent
holes and causing subsequent distortion.
Sharp cutting edges will minimize elastic deformation as the chip is formed. Polished flutes should be used to aid in chip clearance, and a coolant is
required for good drilling performance. The rake angle should be reduced to 0° or a negative angle, and a generous lip clearance (approx. 16°) should
be provided for proper relief.
The point angle is governed by the final wall thickness. Sharp points of 90 to 110° are best for heavy walls and large diameters, while blunt angles
of 115 to 130° are better for thin walls. Close tolerances call for feed ranges of 0.004 to 0.006 ipr. However, a feed rate of 0.015 ipr can be used
where tolerances permit.
That's fantastic guys,
Thanks Heaps.
I'll let you know how I get on.
Thanks,
- Greg H
