Princess 4-pots
phelpsa - 22/6/04 at 03:22 PM
Anyone else using princess 4-pots? How have you connected the two holes together input holes together in the top?
Adam
ned - 22/6/04 at 03:35 PM
stevem is running princess 4 pots on the road. i think he linked a t piece in with copper piping, try u2u/emailing him to be sure..
Ned.
phelpsa - 22/6/04 at 03:36 PM
Thanks ned, will do.
Adam
GasGasGas - 22/6/04 at 04:13 PM
You have to fabricate a link pipe from the first side bleed nipple outlet to the second hose inlet to bridge the caliper and bleed only from the outboard side of the caliper. Thats how its been done on the coversions i've seen.
phelpsa - 22/6/04 at 04:26 PM
Do you have any pictures GasGasGas.
Adam
phelpsa - 22/6/04 at 04:40 PM
http://www.dominicbolton.freeuk.com/brakes.html
Just found this site, says a t-piece going into the two inlet holes is better but because the escort only has one pipe a lot of people do as you described.
Adam
