What if any are the difference between the Ron wishbones and the haynes type?
Ron is narrow track, haynes is wide track... so there is a difference in the wishbones..... Rons are shorter
Ron = Escort Width
Hay = Sierra Width
[Edited on 18/12/10 by Ben_Copeland]
Thanks for that. Next Q can i use Haynes on a Ron chassis
You could, but you'd have to widen the rear to match....
and reallign the mountings, cos they are bound not to be exact
no, is the simple answer
different widths, different lengths, different angles required, different mounting points....... no really, simple or not
lol
