Morning all.
I've been having a think about the design for the de-dion back end I'm looking at fitting to my Sprite. Since the Sprite normally runs on
cart springs, I have helpfully placed mounting points either side of the were the hub plate/tubes will be for the de-dion. What I had in mind was
using Watt's linkages either side to deal with axle location in a similar way to how Caterham do it on their de-dion cars. A bit like this:
The only thought I've been having is whether the axle will now be free to rotate about the pivot point. I know that Caterham use the lower A
frame for lateral location, but does is serve a secondary role in preventing the axle rotating, or am I being overly worried? I was hoping to have
another Watt's, or maybe Mumford, link to deal with the lateral location, and I think either would resist the twisting force, but it's not
what they're there for. It would a simple thing to switch to the Caterham A frame design if it would be better over all though.
I'd rather not using twin trailing arms if I can help it, as it would mean cutting the rear bulkhead, which I don't want to do if I can help
it.
Any thoughts at all guys and girls?
Youll still need a panhard rod to prevent lateral movement and twisting of the axle.
I'm hoping to have another Watt's, or maybe Mumford, link to deal with the lateral location.
Why not use the longitudinal Watts link arrangement used by the Lotus Seven S4 and the live axle Sylva Striker, where you have the trailing and
leading arms above and bleow the axle tube, and the brackets welded to the axle form the vertical link?
This torsionally loads the axle beam in roll, so yo need to either provide a rotational joint on the axle, or (as Sylva and Lotus) use compliant
rubber bushes, but it's simple and it's been proven to work well in practice.
If you're clever, you can also use this arrangement with asymmetric linkages to give a degree of roll understeer.
The problem with doing that, and I have thought about it, is that the arms would probably need to be bent to make it work due to where the chassis mounting points are. Although, the front one will be bolted to the old spring hanger so it could be made a different shape to move the location point up above the axle line.
with how you don't have the arms parallel (thats how it looks in the photo anyway) and using the axle as the centre pivot in a normal watts link,
the axle tube will pivot and rotate in the middle, only a little bit i think, but the bars not being parallel will make that worse. this then will
give you problems on your watts link to stop sideways movement, as your axle tube will be rotating away from it all the time. thats if i've
understood it all correctly
i don't think it will work very well.
also, bending the arms won't make a different. the important bits in suspension is the ball joints on a normal set up. how they join up
doesn't matter. the bars could be bent to a huge S shape bigger than the car, but the movement and affect will still be the same
[Edited on 31/12/10 by blakep82]
Hi There
I've got an S3 Caterham with DeDion.
The Watts linkage is an option, many Caterham's just have one upper radius arm, (like mine), though I think I may upgrade to the Watts linkage as
shown in the pic.
The A frame 'replaces' the panhard rod and lower radius arms as used in a conventional 5 link set up.
In the set up shown, only the A Frame and Watts Link are required to locate the DeDion axle.
I hope this helps?
Ian
[Edited on 31/12/10 by mackei23b]
Blake,
The pic shows the Caterham set up at full droop, if not past it, as the tube is sitting on the lower chassis rail. I'm not sure how different it
looks at ride height.
The lateral Watt's link would probably be rose jointed, so the movement within the joints should allow for a certain amount of misalignment.
Whether it would be enough or not, I don't know. As you say though, I'd rather not having the twisting force imposed on the de-dion tube,
but removing it through a pivot might then allow the tube to rotate. If that's not really a problem, then I'm ok to go ahead as planned and
using a triple Watt's link set up. Which, if I design it right should pretty much eliminate any unwanted axle movements and restrict it to near
pure vertical movement only.
Sam,
Chances are that the links will be all over the place angle wise to clear the de-dion tube. They may even have to be under the axle, but until I get
round to doing a proper design, rather than back of an envelope type, I won't know for sure.
Mackie,
When you upgrade a Cat to the Watt's link, does the A frame change at all? I'm not sure if it stops the axle twisting round or not. The only
thing I can think of is that with the Watt's link, the lower A frame now enforces a twist on the de-dion tube as it moves up and down due to
moving in an arc whilst the Watt's should be a straight line.
Originally posted by mackei23b
...many Caterham's just have one upper radius arm, (like mine), though I think I may upgrade to the Watts linkage as shown in the pic.
...the lower A frame now enforces a twist on the de-dion tube as it moves up and down due to moving in an arc whilst the Watt's should be a straight line.
That arrangement is best used only with a de ion tube not a live axle ---- in fact it is really only ideal for a De Dion with inboard brakes.
The Watts link is a straight swap for the upper radius arm, the A-frame stays the same.
Ian
Blake,
The pic shows the Caterham set up at full droop, if not past it, as the tube is sitting on the lower chassis rail. I'm not sure how different it looks at ride height.
The lateral Watt's link would probably be rose jointed, so the movement within the joints should allow for a certain amount of misalignment. Whether it would be enough or not, I don't know. As you say though, I'd rather not having the twisting force imposed on the de-dion tube, but removing it through a pivot might then allow the tube to rotate. If that's not really a problem, then I'm ok to go ahead as planned and using a triple Watt's link set up. Which, if I design it right should pretty much eliminate any unwanted axle movements and restrict it to near pure vertical movement only.
Sam,
Chances are that the links will be all over the place angle wise to clear the de-dion tube. They may even have to be under the axle, but until I get round to doing a proper design, rather than back of an envelope type, I won't know for sure.
Mackie,
When you upgrade a Cat to the Watt's link, does the A frame change at all? I'm not sure if it stops the axle twisting round or not. The only thing I can think of is that with the Watt's link, the lower A frame now enforces a twist on the de-dion tube as it moves up and down due to moving in an arc whilst the Watt's should be a straight line.
So, over all then, no-one can see anything major that would stop this working as an idea?
I will make a model of it all before I move onto making the real thing so that should show up anything I've over looked.
Thanks for your help, and if there's anything else that you can think of, please let me know!
How are you going to stop the diff nose moving upwards / downwards if you don't fit some form of trailing / leading arm?
(read this thread yesterday from my mobile and couldn't figure it then, headache now is stopping me from grasping it)
Yup, the clues in the title!
De-dion set up for the back of a AH Sprite.
So what are folk's opinion's on whether a lateral Watt's linkage is capable of resisting the rotating motion of the axle? If not, then
I may well bin that idea in favour of the A frame that Caterham use. That might even be easier to do as well, as I could make the front springs mounts
bigger so they double up for both mountings.
PS, Sam-68, are you the same Sam with the FW400 from the kit car section on PH?
Originally posted by DIY SiPS, Sam-68, are you the same Sam with the FW400 from the kit car section on PH?
Originally posted by britishtridentIt will only work on a live axle for very limited suspension travel (as on Lotus Seven S4) .
Ok then, sounds like I might be better off with a Caterham style A frame lower link than a Watt's link for lateral location. It might even make a
few things slightly easier, as although it will introduce an arc to things, as Sam said, I can make the longitudinal Watt's links move in a very
similar way to get a near straight movement. This would then allow me to have the coil overs slightly off vertical, which would help with the limited
room I have too.
It'll also be easier to make too. And possibly a bit cheaper.
Now i grasp its de-dion, don't you risk introducing a (large) twisting load into the de-dion axle if you go through a one wheel bump? Its going to rotate that side of the axle by the amount of bump + multiplied by the distance the de-dion axle is from the centre of the watts link (although on the bright side, you could say its a huge anti roll bar).
Nearly right Sam. The mounts will be in a near horizontal line inline with the axle, if not under it in bump.
And due to the way a Sprite is built, the rear spring mounts aren't as strong as the front ones. Due to being a tiny two seater, the rear
bulkhead sits just behind the seats and has the front spring mounts in it's base. The rear mounts aren't as strong as they hang out from the
boot floor, with just a simple chassis leg for support. Because of this, I don't want to impart any twist down the longitudinal arms if I can
help it, so that counts the S4/Sylva stuff out really.
Using the Caterham Watt's link will, as Sam says pretty much remove/restrict the roll steer with out introducing any unwanted forces into the
mounts. So it seems that this may well be the way to go.
Oh, whilst I'm not sure if it will make any difference, total suspension travel is likely to be 5", possibly a little less.
I'm still not sure I'd rule out the Sylva/S4 solution so quickly, if I were in your position.
The Caterham linkage still requires an A-frame or lower trailing arms to complete the longitudinal location, is much more complex (hence more costly
and heavier; certainly in terms of unsprung weight and probably in terms of overall weight, even allowing for beefing up of the rear chassis pickups),
and doesn't restrain the axle as well against heavy braking loads. The extra accuracy afforded by the ability to fully Rose joint it is offset by
the fact that the dimensions of the vertical link on the bellcrank need to be so compact that even the tiniest amount of play or flex is magnified
geometrically (and there are more joints for the play to occur in...).
The Sylva/S4 solution works at least as well in practice and has the additional advantage that it's very easy to adjust the asymmetry of the
Watts links to fine-tune the roll-steer characteristics.
5" total suspension travel certainly isn't a problem: the Sylva certainly has a lot more than that.
Has anyone got any links or pics to do with the S4/Sylva set up so I can have a closer look at it?
There are photos of the Sylva live axle arrangement in the Raw Striker build manual (page 16), which can be downloaded here (click the icon of the
little man with the spanner, under 'self build' ) :
http://www.striker-cars.co.uk/striker/
I have diagrams of the Seven S4 arrangement (similar in principle to the Sylva arrangement, but uses a diagonal brace to one of the lower trailing
arms for lateral location, instead of a Panhard, and uses shorter arms, hence needs softer bushes), but I've no conveninet means of scanning them
until I return to work next week.
[Edited on 2/1/11 by Sam_68]
