Hi all,
I just want to double check that if I have a 4 stud Ford fitting hubs can I fit ANY Ford 4 stud wheel?
I understand there are different offsets but is there any other 4 stud patterns?
Cheers all.
I bet this gets a fast answer . . . . .
Ford pattern is 4x108.
Simple check with the tape, but you need correct offset to stop upsetting steering geometry or the wheel clashing with callipers, suspension etc.
[Edited on 15/1/11 by coozer]
Actually Ford PCD is 4.25" --- used from the 1959 Anglia 105e onwards 108mm is just a very very close approximation.
"older Fords" ie pre-1958 were 4.5" pcd.
I don't recall Ford ever building cars with 100mm or 4" PCD.
[Edited on 15/1/11 by britishtrident]
5 stud granada IS different from 5 stud mondeo.
Originally posted by britishtridentI don't recall Ford ever building cars with 100mm or 4" PCD.
This might help http://www.bikerlifestyle.co.uk/tech/pcd/pcd.html#m
So Millimetres have nothing to do with the metric system adopted in the 60s then?
some Ford Escort models.
[Edited on 15-1-11 by MakeEverything]
Well I brought the cossie latice wheels so lets just hope they fit and dont rub. If they dont fit I will sell them on!!
ford 4 stud pcd is 4 1/4 inches on all escorts cortinas fiestas etc.
[Edited on 15/1/11 by g.gilo]
