Helping a friend with a Vauxhall Vectra B rear suspension I discovered the rear upper track control arm on these uses a spherical bearing as the
outer bush --- complete with dust seals. I have since discovered these bearings are available as aftermarket replacements which are dirt cheap.
VAUXHALL VECTRA B REAR SUSPENSION ROSE BUSH 95-03 x4 on eBay (end time 17-Feb-11 09:32:45 GMT)
[Edited on 29/1/11 by britishtrident]
Any dimensions?
Dirst cheap aftermarket replacements are available because they sell thousands because they basically dont work in that environment and wear at an alarming rate! They are also fairly big and heavy for what they are
Curious comment - they work as lower control arm bushes on the ST185 and last approximately 125 - 150K miles on a 1400kg 200hp 4wd no problem?
The same item, or something which looks a little bit similar?
Not the same part number, but full booted spherical joints...
Toyota
Vectra:
Unless I mis-read your post intention?
[Edited on 21/3/11 by coyoteboy]
I hesitate to say this, as I'm bound to get it wrong, but I THINK Procomp use a similar kind of joint but smaller/lighter/neater.
The vectra ones are the only ones of which I have specific experience and were the ones mentioned in this thread. To put it lightly theyre crap and the internet is full of reports of early failure, as is any vauxhall garage. Im not saying the principal of a joint of that type is poor, but I wouldnt put that particular vectra component near ANYTHING I was designing from scratch.
I getcha, I read it as "sphericals shouldn't be used in that location".
They're damned expensive from Toyota, might show a quality difference too I suppose (£35 each)
I'd not be going near poly bushes - well known for turning your car into a boat (at least with the GT4s), if they have developed something as a replacement it would be nice.
Nothing handles like the correct spherical - it should not have translation in any axis, only rotation, otherwise it throws out the suspension
geometry. Poly won't cut it, it's been tried and tested over and over.
On the back of the Four it [non-constrained bushes like poly] allows the wheel to effectively have free-play in the toe settings for each wheel, which
makes it do scary stuff and wear the inner edge of the tyres VERY fast.
Nothing handles like the correct spherical - it should not have translation in any axis, only rotation, otherwise it throws out the suspension geometry. Poly won't cut it, it's been tried and tested over and over.
On the back of the Four it [non-constrained bushes like poly] allows the wheel to effectively have free-play in the toe settings for each wheel, which makes it do scary stuff and wear the inner edge of the tyres VERY fast.
I am, and adding more flex to the whole structure is a mistake. I'm not saying it for the fun of it, it's a proven point by both amateurs
and professional rally prep guys alike. Many have tried the poly bushes assuming the advice is wrong/misguided, and found it was the worst
"upgrade" they had ever done, then subsequently gone back. Of course there have been people who have no understanding of vehicle feel and
handling and are perfectly happy with them.
Ever had the trailing arm bushes go on your 205, giving you variable camber
? It's a similar sensation to that.
Sorry if this a thread revival but did anyone ever find an alternative for the 36mm Toyota spherical/rose joint?
