hi all
does anyone now the range of motion +/- ????? Deg for the maxi lower ball joint and transit drag link used on many kit cars????????
thanks tilly
Transit drag link has restricted movement compared to the Maxi suspension joint. So the Transit part tends to be the limiting factor in how much
suspension movement you can get.
How much articulation the Transit drag link has seems to vary between ball joint manufacturers as a drag link doesn't need much
articulation in its original application, so I would advise buying one/two and measuring the angle it will move through.
[Edited on 23/2/11 by britishtrident]
ok thanks
tilly
