fury shock/ spring spec
mrwibble - 7/3/11 at 03:19 PM
After chasing steve a couple of times for a price from pro tech for a set of springs and shocks i've decided to ring them directly. can anyone help me with the specifications required for a road going car engined fury.
ta.
mrwibble - 8/3/11 at 04:22 PM
ok so as far as i can tell i'm looking for 4 x 12.5" fully extended eye to eye centres with bonded bushes 1/2" x 1.25" springs 150lbs rear 190lbs front.
does this sound right?
alfas - 8/3/11 at 09:04 PM
spring rates sound ok
total length of shocks sounds not too bad...unfortunaltely my sylva isnt stored in my home-garage...otherwise it would have been an easy check for me.
is protech not able to help..i mean they should have done dampers for a fury already?
adithorp - 8/3/11 at 09:37 PM
I've got 12" open 8" closed. 1/2" bore bonded bushes. 2" springs 180lbs rear, 210lbs front.
The springs you've listed are about standard but there's been a few recently going to the heavier ratings with good results. Try asking on JPSC forum.
alfas - 8/3/11 at 10:39 PM
oh..what i should have asked: live axle or IRS.
@adi: you mean 2.25 diameter coils, i guess?
mrwibble - 9/3/11 at 01:43 PM
thanks for the replies. i'll ask on jpsc.
sorry yes meant to say its irs.
