Hi all
i was given these break callipers today and was told they were for a sierra they came out of a garage that once housed a cossi?
I put them up against my donor ones and the body is bigger, the pad carriers are the same and all the bolt patterns are the same.
First one to identify them gets a GOLD STAR!!!
Many thanks
Mark
Mark
there are different size front calipers on the cosworth...
240mm disc I think
if they are for the cossi i will buy some disk but im not shore they are cossi ones
2wd sierra cossie's have 4 pot calipers that suit 283mm vented discs and totaly different hubs
4x4 sierra cossies, escort cossies and granada 24v cossies have single post front calipers and suit 278mm vented discs (I think these might be a 60mm
piston too ? )
normal sierra's with ABS, V6's or 4x4 have single pot calipers with a 60mm piston to suit 260mm vented discs (also used on some RS
turbo's)
most of the rest have single pot calipers with a 54mm piston to suit 240mm vented discs (although the 1.3;s and some 1.6's had 240mm solid
discs)
I've got ones for 260mm discs here and they have different numbers from your pic....
[Edited on 26/3/2011 by mcerd1]
most motors factors should be able to id it for you..
if your struggling i can phone amk or brake enginering and find out for ya
stuarty
possibly these????
ford Ka 93- 2008 (1.3)
scroll down to about half way, look for the casting number 48/20.
BCA2982 - 6542 , BCA2983 - 6542 at £74 each.
http://www.brakepartssuperstore.org.uk/contents/en-uk/d6542.html
also google the 815
comes up with Ka passenger side in a couple of locations.
thanks guys i will try car spears shop if your right you get the GOLD STAR!!!
